why we need to give the same data in value column to the formula column within " "
Pls find the image in that why manufacturer name is repeated in formula column inside " ".
What is the need for this and why?
Solved by rosskirby. Go to Solution.
A lot of manufacturers do this to "lock" the value of the parameter. Usually it's just for proprietary information (i.e. website, product name, etc.), and can safely be deleted in the Formula column.
