Revit Architecture
srameshburndy
Message 1 of 4 (144 Views)
what is the relation between value and formula in family type window?
144 Views, 3 Replies
04-17-2013 01:22 AM
why we need to give the same data in value column to the formula column within "  "
Pls find the image in that why manufacturer name is repeated in formula column inside " ".
What is the need for this and why?
rosskirby
Message 2 of 4 (120 Views)
Re: what is the relation between value and formula in family type window?
04-17-2013 06:10 AM in reply to: srameshburndy
A lot of manufacturers do this to "lock" the value of the parameter.  Usually it's just for proprietary information (i.e. website, product name, etc.), and can safely be deleted in the Formula column.
Ross Kirby
BIM Manager
Arcturis
Distinguished Mentor
Caddman13
Message 3 of 4 (119 Views)
04-17-2013 06:12 AM in reply to: srameshburndy
You don't have to do this. The reason for this is so people can't easily change it under the properties palette under edit type. If you want to remove it you have to open the family and remove it in two places.
That is my thought on the reason. It doesn't hurt anything if it is there or isn't there.
srameshburndy
Message 4 of 4 (94 Views)
04-17-2013 05:51 PM in reply to: rosskirby
Thanks Ross
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
