Yes, the Journal Files (see Tutorials under HELP menu - search Journal files):
Click the General tab and make the following changes:
Under Notifications, select your preferred Save Reminder interval, and select Normal for Tooltip Assistance.
Under Username, enter the name you want to use during worksharing. Your login name displays by default.
Under Journal File Cleanup, select values for When number of journals exceeds and Delete journals older than (days).
Journal files are deleted automatically after their number exceeds the value you specify. Journal files are text documents that record each step during your Revit Building sessions. These files are used primarily in the software support process. Journals can be run in order to detect a problem or recreate lost steps or files. They are saved at the termination of each Revit Building session.
Mel Persin, AIA
