I don't think you can do what you are wanting to do. However, you can
either set your detail mode to coarse and manually draw in the extra layers
using details lines, which may not be too bad if you are doing a large scale
plan, or you can edit the structure of the existing walls to only have 1
layer, like how the generic walls are built.
wrote in message news:5397174@discussion.autodesk.com...
I have a project that has existing and new walls . . . my dilemma comes
when I have a detailed unit plan where I need to dimension to the face of
stud - differentiating between the two. I would like to see my new walls in
the "fine" mode, but the existing walls the way they look in "course mode.
Is there a way to set up my view settings, or the settings of the wall so
that the existing walls don't show detail when in "Fine" mode. I can attach
a file if this description is too confusing. Thanks in advance.
L-
