trying to use sweep to create cabinet body
3 REPLIES 3
381 Views, 3 Replies
I am currently trying to make the body of a cabinet with a sweep, but I do not know what profile to select so that I can adjust the height! Or if I can even make a body of a cabinet with a sweep.  It looks like the body of the cabinets within Revit are built using a sweep.  Any advice would be great!!!
Thank you
-Brittany
3 REPLIES 3
maciejwypych
When you creating a sweep, you can just click on Edit Profile, it's located just below the profile selection.
Draw the profile and add parameters to control the width & height.
Hope that helps,
Maciej
Can you send me an image file of that cabinet or send me your Revit file in which you want to create that cabinet??? you just create it with any option. Actually i want to see the shape of that cabinet.
Thanks & regards,
Subhradeep Sen
Kolkata
India
here is the file in a project
