Make sure you aren't trying to load the Timber Framing family while in the
Column command (or something similar). If you try to load the wrong family
type while inside a command, you get this error. You need to be in the
Column command and load the Timber Column family. Or just use the Load
Family command from the File menu.
-MJ
wrote in message news:5367901@discussion.autodesk.com...
Can anyone help us with an error message when loading timber columns "the
family is not the correct category"? We are unable to load wood posts!
