text & dimention scale
7 REPLIES 7
Message 1 of 8
eng_mut
323 Views, 7 Replies
help
when i change the view scale , the text and dimention scale didn,t change
how it can fit to view scale
thanks
7 REPLIES 7
Message 2 of 8
AJA14
in reply to: eng_mut
What happened is exactly correct because on sheet both texts and dimensions will have same size regardless of the scale.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Message 3 of 8
mahindra2513
in reply to: AJA14
how do we change the scale for large scale drawings in order to avoid mess?
Message 4 of 8
loboarch
in reply to: mahindra2513
Use less annotation on a larger scale view or change the text type to use smaller sized text.
I would probably argue the 2nd solution is probably just as bad as doing nothing as the text will become unreadable at smaller sizes.
Different scaled views are meant to convey different information. It would be quite rare I think to see exactly the same annotation on a view 1:100 as I would see in a view of 1:200 or 1:50.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 5 of 8
mahindra2513
in reply to: loboarch
if we go for large scale, fitting in sheets will be the problem.
Message 6 of 8
loboarch
Then I guess smaller text is the answer.
Maybe hand out magnifying glasses with each sheet set issued.  Smiley Happy
Jeff Hanson
Revit Help |
Message 7 of 8
Break up the plan to several Sheets.  That is a normal practice for every large project.
Message 8 of 8
bimscape
Your Annotations (dims, text, etc) are independent from the scale of your model.
The Annotatiuons are full size- ie you want 2mm high text, then that's what you put down- it will always be 2mm regardless of the scale you choose for the view.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Rail Community
