came in to work this morning and have not been able to open my project file in revit. Tried restarting revit several times. tried shuting down and restarting computer several times. no help. I can open a new file in revit no problem, it seems to only be the project file. my team members are not having this issue, it's just my computer. It will load to about 95% and then stop responding. any ideas before i uninstall and reinstall revit?????
Are you opening your existing local copy, or opening the central with "create local copy" activated (recommended) to orverwrite your old local copy?
thanks for responding.. i'm doing the later... openign central and creating new local copy (overwriting the old)....
Did you try login on your own computer as a different user, and try to open the central again?
