Revit Architecture
Valued Contributor
sgoodmansen
Message 1 of 3 (397 Views)
strange mullion lines on curtain wall
397 Views, 2 Replies
08-21-2012 04:47 PM
I am getting some strange dividing lines in my mullions on a project, which I can't seem to get rid of.  See the attached files.  Both projects were started from the same template.  The mullions are the same type in both files.  I even purged and copied the curtain walls and mullions to make sure they were the same, yet I can't get rid of those extra lines no matter what I do.  Please help.
Valued Contributor
sgoodmansen
Message 2 of 3 (364 Views)
Re: strange mullion lines on curtain wall
08-22-2012 09:32 AM in reply to: sgoodmansen
nevermind.  Sometimes its the simple stuff that gets you.  Somehow a surface pattern was added to the material.  Setting the pattern to none fixed it.
rosskirby
Message 3 of 3 (335 Views)
08-23-2012 01:03 PM in reply to: sgoodmansen
Just be careful that when you changed the surface pattern that you don't have any other objects using that same material, otherwise they'll now be missing the surface pattern.  I'll often see this if someone has edited a material on the fly, not realizing that it was being used somewhere else in the project.
Ross Kirby
BIM Manager
Arcturis
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
