spot dimension
1 REPLY 1
184 Views, 1 Reply
spot dimension
I am wondering if anyone has a solution for this problem
I am placing a spot elevation on my section view.
I have a floor with two layers, concrete and screed. and i want to show the height of the structural layer (concrete).
Is this possible because the spot dimension always seems to snap on the top of the floor (screed)
Regards
Sigurjón
1 REPLY 1
alecatalan
You must selecr the level of detail given the option FINE and so you can select the required element.In the COARSE level of detail showed only a single element to represent the slab and that is why you can not do the required.
Alexis Catalán
CAD/BIM Administrator
