You'll want to make three (separate) stairs then, one for each bottom run up to the platform, and then the one that goes up from there. By setting the levels and the Offsets correctly, this shouldn't be too hard.
You might want to use a floor for the platform as well in this case, instead of having it be part of the stairs.
