ewilde wrote:
> So is there no way to create different tags for each wall type and have it label a specific tag to the corresponding wall type? Does that make sense?
No, using OOTB tags, you cannot tag the same wall type, Generic-6" for
example, with different values in each tag.
If two walls are indeed different (hence the need for different
designation on the plans), then properly model them as such by creating
a new wall type in the project browser and using it.
Alternatively, you *can* create instance-based tags and manually input
different values for each and every wall if you wish. But you'd be
missing the point of Revit as a BIM platform capable of accurate modeling.
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
