Revit Architecture
Active Member
Message 1 of 6 (338 Views)
select glass panel
338 Views, 5 Replies
04-14-2012 05:05 PM
Hi there,
I'd like to select glass in curtain wall to put door in it  , but it didn't select .......why?
attach Jpg for it
Valued Mentor
vector2
Message 2 of 6 (335 Views)
Re: select glass panel
04-14-2012 05:16 PM in reply to: msheir
You probably just need to tab until it gets the panel.
Active Member
Message 3 of 6 (321 Views)
04-14-2012 06:45 PM in reply to: vector2
Thanks for your reply
New Member
Message 4 of 6 (277 Views)
04-19-2012 08:53 AM in reply to: msheir
Also try this when you put in the door it should have a offset for it and just raise the offset and the door should apper I had the same problem and once I did that it was fine same goes for windows.
Active Contributor
CSEnginuities
Message 5 of 6 (264 Views)
04-19-2012 06:39 PM in reply to: msheir
Here's a good video with the "Tab" selection method another poster mentioned --
http://youtu.be/zuNuFEdz8yM
My personal preference is to select items by filtering a selection -- whatever works best for you.  To filter a selection, first define a selection box (left-to-right or right-to-left just like in AutoCAD) which contains the panel you want to select.  When you do this, you'll see a "Filter" icon automatically pop up on the ribbon (across the top of the Revit window).  Select this, then check or uncheck categories so that the item you want to select is the only item checkmarked.  If your selection box only has one panel contained, you should see a "(1)" in that category.  Hit OK then you should be good to go with swapping the panel out with a door.
G'luck!
Clara
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
parveen.revit
Message 6 of 6 (247 Views)
04-20-2012 02:41 AM in reply to: msheir
It's important to bring the cursor at any edge of that panel, you can't select it from center.
Once you bring it at the edge, see the status bar at the bottom of revit interface, press tab to select he desired panel.
The selection window is also a good panel but you need to make sure that the selection windows captures only one panel. then you can use filter to select that single pane.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
