Revit Architecture
Valued Mentor
gh_ar
Message 1 of 7 (242 Views)
schedule in to sheet
242 Views, 6 Replies
11-27-2013 12:27 PM
Hi
I have a problem put the schedule in to sheet.
I have much of choices on schedule And I need.
I have used sheets A3.
Note: I selected all the options I need on schedule And A3 sheets should also be.
The problem now is schedule sheet is much larger than And will not be the print.
Is there any way that we can split the same schedule and put in other sheet,  So that Continues to be the each other?
constantin.stroescu
Message 2 of 7 (237 Views)
Re: schedule in to sheet
11-27-2013 12:50 PM in reply to: gh_ar
  1. On sheet click first on the small symbol on right to split the table
  2. then adjust each divided table by draging from the point marked...
1
2
Constantin Stroescu
BIM Manager AGD
Valued Mentor
gh_ar
Message 3 of 7 (208 Views)
11-27-2013 11:07 PM in reply to: constantin.stroescu
Hi
No - this method does not work .
See the image below Schedule is much larger than A3.
The reason why I want divide schedule Each part On a separate sheet Put.
Distinguished Contributor
awes
Message 4 of 7 (200 Views)
11-28-2013 12:38 AM in reply to: gh_ar
I don't think there will be a that  simple solution. We would need an add-in that splits the schedule into sub schedules. The size of the schedule is based on the chosen sheet size. Then it pushes the sub schedules on the sheets and creates a cover sheet. Voila!
My workaround is to export the schedule into Excel, print the schedule as pdf and add a cover sheet as first page.
constantin.stroescu
Message 5 of 7 (194 Views)
11-28-2013 01:24 AM in reply to: gh_ar
It could be done even so..:
Take in consideration that the same Schedules unlike other Views can be inserted into two ore more sheets
In my case I have inserted the splitted schedule on two sheets and draw appart the splitted parts so to fit on sheet borders.....here i s a little work to do ...
I have attached the two printed to pdf files...
Constantin Stroescu
BIM Manager AGD
Rave.Tam
Message 6 of 7 (174 Views)
11-28-2013 04:50 AM in reply to: gh_ar
I have a parameter called "Schedule ID" for the category i want to schedule.
Then i select the first hundred rows in the schedule, then switch to a plan view, and in the properties, change the Schedule ID value to 1. Then select the next 100, and change the ID to 2..
After all the hard work, you should be able to split the schedule using filter
(Actually i have an addin to fill in the schedule id automatically, so this methods works for me)
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Valued Mentor
gh_ar
Message 7 of 7 (155 Views)
11-28-2013 11:02 AM in reply to: Rave.Tam
Hi
I had exactly the same
Thank you very much
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
