Yeah, this goes back to what I said earlier, Revit seems to construct
roofs from the bottom up. Therefore it starts the cut where the plane
intersects the underside of the roof. I think that it would be more
intuitive if the roof was cut at the intersection of the upper surface
of the roof and the cut plane. To get that effect just measure the
height of the vertical cut surface and use that number (remember to make
it negative) as your cutoff level offset and you will be good to go.
I would guess that the program makes a vertical cut because in most
cases the cut roof will abut a wall or the vertical cut of another roof.
Robert Witte
tnitke wrote:
> I think I figured out what is happening. If you look at the first image I supplied, the elevation I was viewing was in "hidden line" mode, so it didn't look like the roof was being cut by the Level. This image shows a roof that has a Cutoff Level of Roof2, and this time I am showing it in wireframe. Now you can see that the roof actually does get "cut" at the correct level, but then Revit continues the roof vertically instead of cutting off the roof horizontally, like a true "cutting
> plane" would do.
