Hi I am new to revit and was wondering if you could help me. I attached a photo of the project i am working on. Im trying to figure out how to create the roof on the left hand side of the taller area. It should be a arched roof just like the others except it is also rounded.
can you post a Plan View of your building and a rough hand sketch to show how you intend to make your roof ?
Constantin Stroescu
Here are plans of the building if you look on the roof plan you see how its rounded and in the elevation haw its at the same time arched. thnx
For the corner arch I suggest using Roof by Face on an Massing Element , an In Place Mass. The In Place Mass will be an intersection of an extruded Arc Shape with a Trucate Cone Void
As for the roof itself you have to use a flat roof with Modify Subelements...
Constantin Stroescu
