revit 7.0 speed
10 REPLIES 10
Message 1 of 11
290 Views, 10 Replies
revit 7.0 speed
is it just me or does R7 seem to be a bit slower than R6?
10 REPLIES 10
Message 2 of 11
Slower than slow actually.
the longer you use it the worse it gets. I think there may be a memory leak.
There is a 400 Reply News thread at augi's website on it.
Message 3 of 11
Turn on Open GL on your video card and on Revit Settings, also uncheck Overlay Planes.
It did improve dramatically my computer
Message 4 of 11
I agree, Revit 7 Seem to loss speed the more time you have it open, Some times if you restart your system this can help for a while.
Also has any one had a problem with operating systems
:Re Work station running XP Pro to Server running Windows 2000 opertating system.
Message was edited by: Dav21
Message 5 of 11
Did you download the last build?
Message 6 of 11
The speed will be a longlasting issue for Revit as a result of BIM. Rendering speed in Revit is horrible since the model is just not for graphic presentation purposes. I made professional renderings out of 3ds 2.0 till 3ds MAX 6 and I never had to bring so much detail into my models. I think Autodesk wants too much out of this product and is ignoring the usability issue. As an architect having done both 3D renderings and CDs, I think Revit is good for making CDs, but does Autodesk really think professional 3D artists would use Revit model for their renderings? Give me a break.
I remember clearly what my professor told me when I was a graduate student - "Stay focused, and stay focused."
Message 7 of 11
But I think you are missing one of the many advantages of BIM: model
(draw)it once, use it everywhere AND have it always up to date. BIM is
all about making your data work harder for you. In my office the same
exact model is used for design, CD's, and presentation renderings.
The rendering speed issue has more to do with outdated and somewhat
obsolete rendering technology currently embedded in Revit (accurender3)
than with the amount of data in the model. Using today's advanced
rendering technologys (vray, brazil, etc), and the rapid advances in
hardware, the amount of polygon simply does not matter as much. We
render all of our Revit models in viz with Vray Advanced, rendering
times are a tiny fraction of what the would be using accurender, and the
quality is exponentially better. What's even more exciting is that there
is a company is working a Revit to Vray plug-in right now! I've
attached a few examples of renderings I have done of our Revit models.
Is there more data that if just created for presentation purposes? Of
course, but that hassle of maintaining two unconnected models far
outweighs any slow down in rendering time. Think about how much a pain
it is the change the model as the cd's change. Plus there are ways of
only rendering what you need for a particular view, such as scope boxes,
worksets, section boxes, clipping planes, etc, you just have to look at
the program.
my 2c,
Z
Message 8 of 11
As for your 3D rendering speed slowing down... I create a "3D Export" I use
the worksets feature to create a "Core" workset which has just the outside
elements in it. I set the "3D Export" view to just show the site and Core
worksets. I then export that view to DWG(I would like to send it straight
to MAX i'm on Revit 8.0 with VIZ 2006) and import to VIZ.
wrote in message news:4933205@discussion.autodesk.com...
Message 9 of 11
I clearly understand the benefit of BIM, but my point is not all designs in the real world have a complete life circle as Autodesk described. Also people tend to ignore the huge cost associated with making use of old DWG archives. I can make a beautiful sketch based on old DWG files within 10 minutes, but how can I do the same with Revit. I couldn't even import and explode a previous DWG which is only 4M.
Revit seems to me is too intelegent and deprives too much control of the user.
Message 10 of 11
You did this tower sketch in 10 minutes?
wrote in message news:4933718@discussion.autodesk.com...
user.
Message 11 of 11
The attachment is something else, just to show how outdated software can do.
