revit 2015 offline help
2 REPLIES 2
GHASEM_ARIYANI
3403 Views, 2 Replies
Hi
I download offline helpe revit 2015 ,But the CAB format .
How can I use??
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
loboarch
in reply to: GHASEM_ARIYANI
Downloading and installing offline help is part of the installation process.  It is a selection made at the time of install.  You can do a repair or re-install of Revit and during the installation mark that you want offline help installed.  Once installed it will work automatically when you are not connected to the internet, the locally installed help will be called instead.
http://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
There is I option to select it.
I have help.cab with me
