Revit 2014 performance question
I am looking for a way to boost the performance in Revit 2014 while loading or updating complex family’s. The problem at the moment seems to be that Revit 2014 only uses 1 cpu while loading family’s even if you have a high end multicore workstation at hand. So with hardware there is not much you can do.
A possible solution should be in virtualization, i.e. running Revit 2014 in a virtual machine with a single vCpu assigned on a vmware Esxi or Microsoft Hyper-v multi core host. I have tested this solution but ran into the problem that neither Esxi or Hyper-v distribute the load of the single Vcpu in the virtual machine over de multicore’s of the host. 1 Vcpu uses just one core of the host so no cpu performance advantage at all. The best practice of adding Vcpu’s to the virtual machine just lowers the performance of Revit in this case.
Suggestions on possible solutions for revit performance or the behavior of Vcpu in virtualization environments are greatly appreciated.
Jos v Zelst
If your computer is loading a family slowly, instead of updating your hardware, check also the families (it is cheaper). Sometimes it is the way the family is created what really affects the performance of your machine. Here there are some recommendations:
Instead of long formulas, prefer types and no formulas.
Instead of several visibility parameters, prefer family type parameters
Instead of having several types, prefer type catalogs
Instead of "all in one" families, prefer separate families.
Instead of many levels of nesting, prefer just two.
I understand the urgency to make familys lean, but in this case we purposly build them this way to get the most out of it in terms of speed while modeling . so for the revtiteer its a 'simple' change of parameters to make a lot of changes in the family and subfamilys at once. this functions fine
But maintaining the family proofs to be not so speedy.
This performance problem is also not limited to loading familys but making views and placing them on sheets in an automated way also runs into the 'revit uses only 1 cpu' problem
mvgr
