Hello!i' have a big big problem!I just installed Revit 2013 to my Pc with windows 8 64 bit, but it's don't work! I tried to download the update relase but i'can't install. "windows" tells me that "can not install the update relase of Autodesk product requested was not found on the computer. be sure to use the relase proper update for the product".
please help me....I really need to revit!!
windows 8 is not a supported platform
you can look here for workarounds if any: http://forums.autodesk.com/t5/forums/searchpage/tab/message?q=windows+8
DarrenP
Darren is correct that Revit 2013 is not supported on Windows 8 but based on your description, it is not clear if your initial install of Revit is functional or not. It almost sounds like the problem is that you cannot install the latest update. If this is the case, the error you encountered indicates that you are trying to install the wrong version of the update. Make sure you have the correct update for your operating system (32-bit or 64-bit) as well as the version of Revit you have installed (Revit, Revit Architecture, Revit MEP or Revit Structure).
Tony Michniewiciz
Autodesk Revit QA
