Revit Architecture
Distinguished Contributor
joseg
Message 1 of 5 (305 Views)
resize perspective view
305 Views, 4 Replies
04-25-2012 02:29 PM
We have a perspective view which we need to resize so that the building takes up the entire sheet for presentation purposes.  How do we do this?
thanks
IMCornish
Message 2 of 5 (299 Views)
Re: resize perspective view
04-25-2012 02:50 PM in reply to: joseg
If it is an image or a rendered view on a sheet then you can click it and sizing handles will appear or you can just change the width and height figures in the properties window.
If it is a perspective view (which I am sure you mean) you click the view on the sheet then click 'activate view' on the Modify Viewports ribbon. You can then use either of the methods described above, to resize it, after which you click outside of the viewports extents, ensure the View ribbon is active and click, viewports>deactivate viewport.
Hope this helps.
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Valued Contributor
derrickmoore
Message 3 of 5 (292 Views)
04-25-2012 02:56 PM in reply to: joseg
Click the viewport on the sheet and hit the size crop button on the ribbon. Make sure the scale button is selected and then enter the size - it will be in inches, unlike Revit's default of feet.
joseg
Message 4 of 5 (288 Views)
04-25-2012 03:05 PM in reply to: derrickmoore
Thank you guys, that did it.
IMCornish
Message 5 of 5 (262 Views)
04-26-2012 08:59 AM in reply to: derrickmoore
Rick, thanks for pointing that out. I had not noticed this before, but why does it not work for renderings or images, weird!?
Andrew Robertson
Chartered Architect
Truro. UK
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
