are the street light - light families with a light source. If so, make sure that it is turned on, if you have done a day shot, revit may have asked you if you wanted to turn off all lights but the sun. so you need to click lighting on the rendering tab and make sure those lights are on. I like using the default sky and the change the time of day to early evening. for night shots.
