remove a layer of wall on selected parts of a wall
2 REPLIES 2
1995 Views, 2 Replies
Is there a way to remove a layer of the wall on a selected part of the wall?  For example, I would like to removed the finished plaster on a brick wall where at a shaft.  Is there a waz of doing this without creating a new wall type?
Tags (2)
2 REPLIES 2
LisaDrago
You will need to make a new wall type to do that.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Ok, Thanks.
