"Unrecoverable Error" when opening files in Revit 2011
2 REPLIES 2
538 Views, 2 Replies
Been using Revit 2011 for a couple of years and never had any problems until recently.  I attempted to load a component file and got an Unrecoverable Error and Revit shut down.  Now, it appears that any attempt to load or open a file from inside Revit results in this same problem.  I have read multiple posts and solutions and wiped/reinstalled the program.  Nothing has worked.  I'm running it on XP.  If anyone has any suggestions, I would appreciate some help.
2 REPLIES 2
LisaDrago
Hello and Welcome to the discussion!
Have you tried doing an Audit on the file as you open it?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
JHKdezine
in reply to: LisaDrago
i had to install revit 2013.  be sure to also install the service packs too.
