Revit Architecture
Member
krigh
Message 1 of 3 (562 Views)
"Save as new file..." is greyed out?
562 Views, 2 Replies
11-26-2009 02:31 AM
We have been using Revit's "Save as new file..." function to save out files from our Central Model. In our model if I select different floors I get different results. I don't know what causes it to grey out. See attached JPG. Can someone please tell me what in the floor might cause it to grey out? (unfortunately due I cannot upload the files).
Thank,
- Krigh
Active Member
ASI_BSD
Message 2 of 3 (443 Views)
Re: "Save as new file..." is greyed out?
02-20-2012 10:37 AM in reply to: krigh
If you open the floor plan that you want to Save as a New File, and draw a detail line anywhere on the floor plan it will allow you to Save as a New File. Once the file is saved you can delete the Detail Line.
BSD Technical Support
AdvancedSolutions.com
"You may not be able to erase your past, but you are the artist of your future!"
mossbim
Message 3 of 3 (172 Views)
02-06-2014 07:02 AM in reply to: ASI_BSD
My issue with this work-around is when I import into Navisworks I get an error.
I know this becuase its the only view/Level I have an issue with in Revit. All else work fine. Any thoughts ?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
