"Save as new file..." is greyed out?
4 REPLIES 4
5123 Views, 4 Replies
We have been using Revit's "Save as new file..." function to save out files from our Central Model. In our model if I select different floors I get different results. I don't know what causes it to grey out. See attached JPG. Can someone please tell me what in the floor might cause it to grey out? (unfortunately due I cannot upload the files).
Thank,
- Krigh
4 REPLIES 4
ASI_BSD
If you open the floor plan that you want to Save as a New File, and draw a detail line anywhere on the floor plan it will allow you to Save as a New File. Once the file is saved you can delete the Detail Line.
BSD Technical Support
AdvancedSolutions.com
"You may not be able to erase your past, but you are the artist of your future!"
rgilbim
in reply to: ASI_BSD
My issue with this work-around is when I import into Navisworks I get an error.
I know this becuase its the only view/Level I have an issue with in Revit. All else work fine. Any thoughts ?
7 years past.. We are still there. Draw detail line and delete after export - seriously..? Love, you, Autodesk Heart
RDAOU
Seriously? I find that useful...even better than a Promt Message. Both Save and Save as should be grayed out till a change/modification to the file has been introduced to the file. This is not an exclusive Revit feature. At least a dozen other softwares has it.
The "Oh! This file is or has been openned so lets just save it just in case" is more like a Microsoft Word habit
