"Draw" is missing in Modify ribbon
6 REPLIES 6
chetsishah5
4694 Views, 6 Replies
I am using Revit 2013 student version. I don't see draw option in modify ribon. I looked for the solution in the forum, it was suggested to install updates. I installed them (check the attachment). Earlier I could not see Finish Model and Cancel Model options which I see now but I still don't see the draw option.
I have attached the image of what I see.
Please Help...
Tags (1)
6 REPLIES 6
maciejwypych
in reply to: chetsishah5
Did you selected the object that you are editing?
There is no draw tab unless you are creating or editing an object.
chetsishah5
in reply to: maciejwypych
Thanks for replying. Yes I selected the object I want to edit. I have attached the image.
maciejwypych
Select the object, click on the Edit model in-Place.
Now select the object again. You should get Edit Extrusion/Blend/Sweep or Revolve.
Click on that to get Draw tab.
If you want to add an object to the one you edit, you need to click on the Edit model in-Place and go to Create and select the form you want.
And again the Draw tab will appear.
chetsishah5
Hi Maciejwypych! Thanks for replying... It worked!
dane.okane
I'm having the same issue with the missing draw functions in the modify ribbon, but I can't see an "Edit model in-place" option after selecting my walls or lines.
zulfiqarengr28
in reply to: dane.okane
same problem
Rail Community
