I am using Revit 2013 student version. I don't see draw option in modify ribon. I looked for the solution in the forum, it was suggested to install updates. I installed them (check the attachment). Earlier I could not see Finish Model and Cancel Model options which I see now but I still don't see the draw option.
I have attached the image of what I see.
Please Help...
Solved by maciejwypych. Go to Solution.
Thanks for replying. Yes I selected the object I want to edit. I have attached the image.
I'm having the same issue with the missing draw functions in the modify ribbon, but I can't see an "Edit model in-place" option after selecting my walls or lines.
