Revit Architecture
Active Member
ArchInc00
Message 1 of 2 (1,084 Views)
"Disk Full While Accessing" Error Message
1084 Views, 1 Replies
04-17-2013 11:01 AM
We're getting an error message while trying to save to central- "Disk full while accessing filename_central.rvt"
Does anyone have an idea what this is from? I figure it's a space error, but the project is on a server which shouild have plenty of room.
Thanks!
Active Contributor
rkitect28
Message 2 of 2 (1,059 Views)
Re: "Disk Full While Accessing" Error Message
04-17-2013 01:55 PM in reply to: ArchInc00
How much space do you have on your local hard drive? Are you working in a large file all day without shutting down? What version of Revit are you on? How much memory do you have on your local machine and what are the virtual memory settings? If seems like I have had this before a long time ago when I would run out of memory on my local machine and there was no memory left to process or cache information. Remeber you are still caching all of data you open in all of those views on your local machine.
Josh Siddle
www.freelon.com
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
