problem installation revit: Download Failed, Installation aborted, Result=1603
1 REPLY 1
RaisadeHaas
852 Views, 1 Reply
I tried to installed autodesk revit 2014 the student version. But after installation i get this problem.revit probleem.png
Can someone help me with a solution?
Thank you
This is the log file:
2014/4/14:14:52:07 Raisa RAISA-PC === Setup started on RAISA-PC by Raisa ===
2014/4/14:14:52:07 Raisa RAISA-PC Path_Length: 149
2014/4/14:14:52:07 Raisa RAISA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/4/14:14:52:07 Raisa RAISA-PC Launch
2014/4/14:14:52:07 Raisa RAISA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44841604 /PK 829F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/14:14:52:07 Raisa RAISA-PC Current Directory C:\Users\Raisa\AppData\Local\Temp\_AI56C9.tmp
2014/4/14:14:52:40 Raisa RAISA-PC === Setup ended ===
2014/4/14:14:52:08 Raisa RAISA-PC === Setup started on RAISA-PC by Raisa ===
2014/4/14:14:52:08 Raisa RAISA-PC Path_Length: 149
2014/4/14:14:52:08 Raisa RAISA-PC Current Directory C:\Users\Raisa\AppData\Local\Temp\_AI56C9.tmp
2014/4/14:14:52:08 Raisa RAISA-PC Launch
2014/4/14:14:52:12 Raisa RAISA-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/4/14:14:52:38 Raisa RAISA-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/4/14:14:52:38 Raisa RAISA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Raisa\AppData\Local\Temp\_AI56C9.tmp\Setup\RevitSetup.dll
2014/4/14:14:52:39 Raisa RAISA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:14:52:39 Raisa RAISA-PC PageOpen LaunchDialog
2014/4/14:14:55:23 Raisa RAISA-PC PageOpen LicenseDialog
2014/4/14:14:55:23 Raisa RAISA-PC PageOpen ProductInfoDialog
2014/4/14:14:55:23 Raisa RAISA-PC PageOpen ProductSelectionDialog2
2014/4/14:14:57:36 Raisa RAISA-PC PageOpen FullProgressDialog
2014/4/14:14:57:36 Raisa RAISA-PC Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:14:57:39 Raisa RAISA-PC Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:14:57:39 Raisa RAISA-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Raisa\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/14:14:57:56 Raisa RAISA-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/4/14:14:57:56 Raisa RAISA-PC Download Play VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:14:57:59 Raisa RAISA-PC Download Complete VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:14:57:59 Raisa RAISA-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Raisa\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/14:14:58:21 Raisa RAISA-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/4/14:14:58:21 Raisa RAISA-PC Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:21 Raisa RAISA-PC Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:21 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:58:25 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/4/14:14:58:26 Raisa RAISA-PC Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:32 Raisa RAISA-PC Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:32 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:58:41 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/4/14:14:58:41 Raisa RAISA-PC Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:43 Raisa RAISA-PC Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:43 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:58:51 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/4/14:14:58:51 Raisa RAISA-PC Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:52 Raisa RAISA-PC Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:52 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:58:58 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/4/14:14:58:58 Raisa RAISA-PC Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:59 Raisa RAISA-PC Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:58:59 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:59:02 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/4/14:14:59:02 Raisa RAISA-PC Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:59:09 Raisa RAISA-PC Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:59:09 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:59:19 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/4/14:14:59:19 Raisa RAISA-PC Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:59:21 Raisa RAISA-PC Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:59:21 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:59:29 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/4/14:14:59:29 Raisa RAISA-PC Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:59:31 Raisa RAISA-PC Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:14:59:31 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:14:59:37 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/4/14:14:59:37 Raisa RAISA-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:14:59:40 Raisa RAISA-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:14:59:40 Raisa RAISA-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Raisa\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/14:15:00:00 Raisa RAISA-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/4/14:15:00:00 Raisa RAISA-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/4/14:15:00:06 Raisa RAISA-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/4/14:15:00:06 Raisa RAISA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/14:15:00:40 Raisa RAISA-PC Install DirectX® Runtime Succeeded
2014/4/14:15:00:41 Raisa RAISA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/4/14:15:12:42 Raisa RAISA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/4/14:15:12:42 Raisa RAISA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/14:15:12:48 Raisa RAISA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/14:15:12:48 Raisa RAISA-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2014/4/14:15:13:06 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/4/14:15:13:11 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/4/14:15:13:15 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/4/14:15:13:19 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/4/14:15:13:23 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/4/14:15:13:26 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/4/14:15:13:32 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/4/14:15:13:37 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/4/14:15:13:37 Raisa RAISA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/14:15:13:37 Raisa RAISA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/14:15:13:39 Raisa RAISA-PC PageOpen InstallCompleteDialog
2014/4/14:15:59:11 Raisa RAISA-PC === Setup ended ===
2014/4/14:16:05:02 Raisa RAISA-PC === Setup started on RAISA-PC by Raisa ===
2014/4/14:16:05:02 Raisa RAISA-PC Path_Length: 149
2014/4/14:16:05:02 Raisa RAISA-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/4/14:16:05:02 Raisa RAISA-PC Launch
2014/4/14:16:05:02 Raisa RAISA-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44841604 /PK 829F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/14:16:05:02 Raisa RAISA-PC Current Directory C:\Users\Raisa\AppData\Local\Temp\_AI1410.tmp
2014/4/14:16:05:06 Raisa RAISA-PC === Setup ended ===
2014/4/14:16:05:04 Raisa RAISA-PC === Setup started on RAISA-PC by Raisa ===
2014/4/14:16:05:04 Raisa RAISA-PC Path_Length: 149
2014/4/14:16:05:04 Raisa RAISA-PC Current Directory C:\Users\Raisa\AppData\Local\Temp\_AI1410.tmp
2014/4/14:16:05:04 Raisa RAISA-PC Launch
2014/4/14:16:05:04 Raisa RAISA-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/4/14:16:05:05 Raisa RAISA-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Raisa\AppData\Local\Temp\_AI1410.tmp\Setup\RevitSetup.dll
2014/4/14:16:05:05 Raisa RAISA-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/14:16:05:05 Raisa RAISA-PC PageOpen LaunchDialog
2014/4/14:16:08:05 Raisa RAISA-PC PageOpen LicenseDialog
2014/4/14:16:08:05 Raisa RAISA-PC PageOpen ProductInfoDialog
2014/4/14:16:08:05 Raisa RAISA-PC PageOpen ProductSelectionDialog2
2014/4/14:16:08:55 Raisa RAISA-PC PageOpen FullProgressDialog
2014/4/14:16:08:56 Raisa RAISA-PC Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/4/14:16:08:56 Raisa RAISA-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Raisa\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/14:16:09:06 Raisa RAISA-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/4/14:16:09:06 Raisa RAISA-PC Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:06 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:10 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/4/14:16:09:10 Raisa RAISA-PC Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:10 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:18 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/4/14:16:09:18 Raisa RAISA-PC Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:18 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:25 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/4/14:16:09:25 Raisa RAISA-PC Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:25 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:31 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/4/14:16:09:31 Raisa RAISA-PC Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:31 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:34 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/4/14:16:09:34 Raisa RAISA-PC Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:34 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:44 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/4/14:16:09:44 Raisa RAISA-PC Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:44 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:51 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/4/14:16:09:51 Raisa RAISA-PC Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/4/14:16:09:51 Raisa RAISA-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/14:16:09:57 Raisa RAISA-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/4/14:16:09:57 Raisa RAISA-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/4/14:16:09:57 Raisa RAISA-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/14:16:10:18 Raisa RAISA-PC Install DirectX® Runtime Succeeded
2014/4/14:16:10:19 Raisa RAISA-PC Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/4/14:16:18:29 Raisa RAISA-PC Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/4/14:16:18:29 Raisa RAISA-PC Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/14:16:18:32 Raisa RAISA-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/14:16:18:39 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/4/14:16:18:43 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/4/14:16:18:46 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/4/14:16:18:49 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/4/14:16:18:52 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/4/14:16:18:56 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/4/14:16:18:59 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/4/14:16:19:01 Raisa RAISA-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/4/14:16:19:01 Raisa RAISA-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
1 REPLY 1
DannyHubbard
in reply to: RaisadeHaas
Check out this other post from Travis on the errors you are seeing and try the Virtual Agent to download Revit.
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-160...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
