problem The installation
1 REPLY 1
GHASEM_ARIYANI
318 Views, 1 Reply
Hi
I have a problem  The installation I encountered.
The following warning is displayed when installing windows.
Please guide
When to go Text installation log file I click Attached notepad file Will be displayed..
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
1 REPLY 1
hi
Installing the .NET Framework 3.5 on Windows 8 I solved the problem.
http://wikihelp.autodesk.com/Installation_Help/enu/2014/Help/0000-Autodesk0/0002-Installa2/0003-Prep...
http://msdn.microsoft.com/en-us/library/hh506443.aspx
