print to a kip3000
3 REPLIES 3
kate_vanhout
322 Views, 3 Replies
print to a kip3000
Just wondering if anyone else is printing from revit architecture to a kip 3000?  I am having problems printing and I am thinking it has to do with the printer.  So let me know if anyone else is using the same printer!
3 REPLIES 3
l.tucker
in reply to: kate_vanhout
I've heard of a lot of problems, but haven't ever had a chance to use a Kip 3000 myself. Try printing to PDF first and then PDF to plotter. Might help in the meantime!
kate_vanhout
in reply to: l.tucker
Thanks, I will for sure try that! Our biggest problem is that our lines aren't showing up very dark so people in the field are complaining that they can't read the prints as well as with our autocad prints.  right now we are at the point where we are not longer using revit (which is my program of choice!) so I am trying everything I can to fix this problem so we can use this program again!
Jason_S
Not sure what version of Revit you are using but we had a ton of problems once we upgraded to 2012.  The problem was solved by updating the KIP Software driver on the server to 5.76.  We have not had an issue printing to the KIP since.
You can get the drivers from the KIP web site or if you have maintenance program get the techs in to help.
Hope this helps you out.
