If you are using Revit 8.0 you can do it as per attached image. Unlock tile
component(s) in wall edit section dialog box, then in section view drag tile
layer down to your liking.
It seems that version 8.1 isn't allowing unlocking individual wall
components..
Could someone verify that please.
wrote in message news:4992925@discussion.autodesk.com...
Hello-
I am trying to figure out a way to show a bathroom wall that has half height
ceramic tile. I.e. the bottom half of the wall has ceramic tile
wainscoating, the top not. I can't seen to do it by vertically subdividing
regions since the regions must be in plane. I can't seem to do it as a
sweep either since I don't have a profile. Is there an easy way to do this?
