I don't understand why you can't just lock it to the reference lines for the
door? You may have to re-lock the array to the reference lines.
The other way to do this would be to create a width parameter for the line
and set it equal to the width of the door. Width of Line = Width of Door
(or whatever you name your parameters).
The best way to create arrays is to set it up in a separate file and then
nest it in your door family. In the separate file you create all your
parameters, then when you insert it in, you select it and select properties.
Then you can reassign the panel parameters to ones in the door family. This
site has lots of example of nested families, but you'll need to take them
appart to really understand,
http://www.revitfamilyman.com/new3revitfotwpage.htm. I'd recommend the book
shelf family or even the vertical shelving.
Hope that makes sense.
wrote in message news:5369150@discussion.autodesk.com...
Actually all is not well. I've gotten the # of panels parameter all set up
but I can't get the panel lines to change with the door width parameter once
i've done an array. I tried setting up the original array line to lock to
both sides of the opening but once its arrayed its like it forgets that
stuff.
Can anyone get arrayed model lines (projection) to adjust to a width
parameter?
