Revit Architecture
Active Member
caleb-ferguson
Message 1 of 8 (239 Views)
orthogonal drawings
239 Views, 7 Replies
04-06-2014 05:25 PM
how to change a 3d revit drawing into 3 view (top, side and front) orthogonal drawings
constantin.stroescu
Message 2 of 8 (208 Views)
Re: orthogonal drawings
04-07-2014 01:28 AM in reply to: caleb-ferguson
Right Click on the View Cube >Orient to View > Elevations (or Sections) choose the desired...
Constantin Stroescu
BIM Manager AGD
Active Member
caleb-ferguson
Message 3 of 8 (184 Views)
04-07-2014 01:00 PM in reply to: constantin.stroescu
thank you. how do I get the three views (front, side and top) onto one A3 title block with dimensions on it.
constantin.stroescu
Message 4 of 8 (167 Views)
04-07-2014 02:51 PM in reply to: caleb-ferguson
These 3 views are 3d not 2d ....so,it is not advisable to use them instead of elevations and floor plans when placing dimensions.
These views allows rendering - the 2d do not.
Although I did not recomend to use these instead of a 2d, this can be done as a particular case of dimensioning a 3d axonometric view.
This method consists in seting the appropriate Work Plane - as can be seen in the following recording:
https://chronicle.autodesk.com/main/details/39f44c96-a20e-4d7a-b4e0-547147736857
Constantin Stroescu
BIM Manager AGD
Distinguished Contributor
Steve_Stafford
Message 5 of 8 (139 Views)
04-08-2014 04:04 PM in reply to: caleb-ferguson
If you really just want 3D views for each direction on a sheet, duplicate the 3D view, rename and reorient each as desired. Drag each view onto a sheet. Dimensions can be added as long as the view's are assigned to parallel workplanes (as the previous reply mentions). Far better to use Elevation views for documentation since those are already assumed (by Revit) to require dimensions and other annotation.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
Active Member
caleb-ferguson
Message 6 of 8 (125 Views)
04-09-2014 12:17 AM in reply to: Steve_Stafford
thank you, thats helpfull.
another question is when i print the title block with the three views the scale doesn't match up with what the drawings are drawn in. for example a wall length measured on the print out is 250mm and converted with a scale of 1:100 therefore equaling  25000mm (25m), however the measurement entered on the program is actually meant to be 30m. can you help with this, hopfull it's understand this.
alisder.brown
Message 7 of 8 (109 Views)
04-09-2014 06:53 AM in reply to: caleb-ferguson
Could you not just use your elevation views and plan views from your project browser? Or am i reading the question wrong?
If you have modeled it correctly the sizes should be correct regardelss what scale is used (unless you are also scalling the PRINT size in the print settings? A1 inside REVIT scaled to A2 paper)
Alisder Brown
BIM consultant & application specialist
Autodesk Trainer
Active Member
caleb-ferguson
Message 8 of 8 (102 Views)
04-09-2014 07:32 AM in reply to: alisder.brown
no you haven't read the question wrong, however please regard this as now closed as i have found the solution. the printing setting was on 'fit to page' therefore reducing the size of the drawing making it out of scale. thanks for you time
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
