first problem:
1 I open a building section
2 select a wall
3 click the Edit Profile button
4 the function doesn't work
5 I can't escape this function
6 I have to exsit the program without saving data
second problem:
1 in the wall function and similar functions I stopped having the panel Load from Library
2 sometimes I don't have the panel Draw
3 I have to exsit the program and start it again
the third problem:
the color of markers changes from blue to brown
everytime, when I start the program, I get a messege "No parent Keynote '06 43 00' for '06 43 00.B1', can be ignored".
I instalted this version of Revit Architecture 2012 on October 13th 2011.
Solved by Joe.Charpentier. Go to Solution.
Revit Clinc has posts addressing all these issues.
Contextual tab issue with .NET 4.5- full description:
There is a Hotfix available:
And the color of Sections:
Joe
