need help in Parameters explanations
10 REPLIES 10
Message 1 of 11
ennujozlagam
466 Views, 10 Replies
Hello Guys,
I used metric generic base.rft i created A trellis using extrusion when i load into my projects the dimensions in the ref. level doesnt change  when i edit in in properties "edit type " the total length not changing only the height of the trellis.
what could be the problem
Please see attached.
Thank you
10 REPLIES 10
Message 2 of 11
CoreyDaun
in reply to: ennujozlagam
Can you attach your Family file here? Also, what version of Revit ar eyou using?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 11
ennujozlagam
in reply to: CoreyDaun
Hi Corey,
Thank you ver much for your reply. Im using Revit 2014. Is there any possibilty can teach me the procedure how to do it.
Message 4 of 11
You have created one single extrusion that contains a great number of these rectangles, all in the same sketch. That is not going to work like an array, is that is your intention. The correct workflow is to make one item (one beam or column, post, whatever) as a family, and then nest that family into another family, and then in this host family, you make an array.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 5 of 11
ennujozlagam
Hi Alfredo,
thank you for your reply. It is not my intention to do that  i really dont know how to do it. I only want is to create a vertical trellis that i can load to my project and at the same time i can adjust the width, height etc in different locations. Any help and procedure you can give is much appreciated.
Thank you,
Message 6 of 11
ennujozlagam
I tried everything i know but it doesnt work. I really dont know where is the mistakes procedure. Please help
File attached.
Thank you.
Message 7 of 11
Instead of making this as a family, have you considered doing this in the project, with the Beam System tool? It's not available in Revit LT, but in the full Revit it is.
Message 8 of 11
Hi Alfredo,
I cannot do this in my project because of the reason that i have different type of trellis in length and height thats why im doing this in Family so that i can control the parametes. Is there anyway you can give me the procedure how to do it, maybe just a capture image if you dont mind. I need to this as soon as possible bcoz in need to submit my proposal tomorrow friday to the owner but until know i dont have any solution how im going to do this.
Thanks a lot for your time and help to those user who is struggle to learn Revit.
Message 9 of 11
The best tool for a trellis is the Beam System tool. After you create the trellis as beam system, each beam is still available for changes if you select it with the tab key.  I don't understand the reason for insisting on doing a trellis as a family, especially considering that you have a deadline, and that making this as a family requires experience with the family editor. Otherwise, it takes a long time to do, time that you can use for other tasks of the project.
Message 10 of 11
Hi Alfredo,
Thank you very much for your quick reply. Is there anyway i can change the materials from steel to hard wood the size is 25x50x3000 for my trellis vertical and horizontal.
Message 11 of 11
You need to load a family from the folder of Structural framing > Wood, into your project, and make the beam system with that beam family.
