Revit Architecture
New Member
Message 1 of 3 (1,290 Views)
nVidia Geforce Graphics cards for Revit Arch.
1290 Views, 2 Replies
10-17-2012 05:58 AM
I am about to purchase a new Dell Inspiropn 8GB memory 64bit laptop which comes with a 2 GB nVidia Geforce GT 650M 130W card.
I will be using Revit 2012 on this laptop and would like to know as this card does not appear on the Autodesk supported card listings (only nVidia Quadro cards there) will it be good enough to work on complex projects. Any advice appreciated.
LisaDrago
Message 2 of 3 (1,250 Views)
Re: nVidia Geforce Graphics cards for Revit Arch.
10-19-2012 06:12 AM in reply to: martin.mallon
Autodesk only tests certain vedio cards. Just beacuse a card does not show up on 'their' list does not mean it will not work. In fact my laptop video card NVIDIA GeForce GT 555M works perfectly (I am running Autodesk Building Design Suite Ultimate 2013 with Revit 2013) -but is not on their list.
That list has created more problems then it is worth.
AS long as you have enough ram and Ghz you shouhld be fine.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
New Member
Message 3 of 3 (1,223 Views)
10-20-2012 03:01 AM in reply to: LisaDrago
Thanks Lisa.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
