Hi
i am using revit 2011 & 2012 but i cannot add a material in baluster.
can you tell me how can in add material in it.
i didnt find any option in type property to select the material but there was an option for railings.
Is adding of material for baluster possible?
please help me
my e mail is sudarshankvarma007@gmail.com
Thank you
Sudarshan K Varma
Solved by LisaDrago. Go to Solution.
Hello - You will need to go to the project browser - family's - Railings - Baluster (select the family you are using) - pick the baluster you want and right click. On the menu you should see type properties - select it - in the type properties you can set the materials.
I have attached a couple of images for reference.
LD
