Hey i have a topographic sufrace already made but i want to add grass how would i do that.
Solved by Alisder.Brown. Go to Solution.
Hey
follow this process to change materials:
If you do want to create a seperate area within your toposurface with a diferent material, follow the steps to create a sub region or split face in your toposurface in the previous post and follow the steps here to change the materials to w/e you wish
Hope this helps 🙂
hey
i didn't find it in the search box nither "grass" nor " hedge" what should i do ?
Moayad
Make sure your "library" section is turned on in your material browser.
See the attached image. There should be two sections on the left and one on the right. (Loaded materials, Full Material library and material properties.
By clicking the small box that is circled in red up top it should activate your materials library section if it is not already turned on.
When you search for materials now, they will show up in the library window if they are not loaded into your curent project. Simply double click them in the library window (bottom left) and they will load into the project window (Top left). Now you can select the material and click OK. (make sure you do this step, you must load the material into the project this way to be able to use it)
Hope this helps
A
hi
first of all thank you very much for answering me.
I have some questions as I am a beginner to use the Revit architecture'. I want to redesign my house as a project so I will start as below:_
1- I will roughly in dimensions draw the topsoil but in this case, I don't know should I use the boundary limits or still early and how to use it .
2- In the properties -phase created in front of phase created there is a choice called [new construction & existing] after I have seen several videos some of them change it to the choice existing and when they try to design the grass or hedge the colour and the materials only changed when I went back to the choice new construction this case also I couldn't understand it?
3- should I take into consideration the level of grass in touch with the underneath level of the concrete floor of my house to be 0.0 or it should be like [-4 inches][-100mm]? and when can I design the pavement or footpath around my house inside the property line or I must put in my mind that I cat go further than the property line.?.
If you can help me to understand the solution of these questions or send me one or two video links that might solve my questions.
Thank you very much
