Why when I load a family does Revit open another view or pull up another view into that project when there is one already open. I could understand if it was a view you might insert that family into however it is random. I''m inserting a furniture system family and it opens the door schedule. Makes no sense at all. Revit 2013 with update release 1.
Chris
Hi Chris,
No, when loading a family, Revit does not bring or create any new views related to the family. Certain views can be 'inserted' from other Projects, ie, schedules, Sheets..........but not from within a family proper. Usually, the first time you "Load into Project" from within an opened family, it will essentially come in under your mouse pointer in a plan or elevation view. It will not (or should not) open a schedule as you cannot place families into schedule views, and should not be launching any schedules..............Did you by chance have a scehule view opened as well as a plan view wehn ylou inerted the family...sometimes depending on the graphics card and drivers, the view will 'switch' when loading families/views to another 'open view' as it regenerates the graphics.
Mike
Yes this is a repeatable event.
I have a family open and a project open. While in the edit family window I hit "Load into Project" on the ribbon and the window comes up may be a plan view or a sheet view or a schedule. The family never comes up under the curser ready to be placed. Sometimes it will open a duplicate of a sheet view already open with a "(1)" in the name. This view disappears when it is closed and never shows up in the Project Browser.
I'm using Revit 2013 however the same behavior occured in 2012. It's a Dell Precision T3500 zeon W3530 2.8 GHz 12 GB ram, Win 7 64 bit Nvidia Quadro 2000. All current drivers and updates installed.
Here is a screen capture of the same sheet open twice after trying to insert a drafting view from another project also saved in 2013. I don't think you can do this on purpose.
