If you are using the Opening tool to cut the hole, it will go all the way
through the object. You should create a Void that is the size of the hosted
object, and assign it to cut the host.
-MJ
wrote in message
news:6061397@discussion.autodesk.com...
This whole idea isn't working out so well....I turns out that if you cut the
hole in the bottom of the floor of the host floor the hole goes all the way
to the top and you can see the hole in the floor above. I guess this would
be OK if your floor consists of just joists and subfloor - then the holes
could be covered up by another floor layer of finish material.
James (again)
