Revit Architecture
jeevanjacob
Message 1 of 3 (126 Views)
length of the beam ?
126 Views, 2 Replies
12-10-2012 11:17 PM
I have all my columns in position. I need to draw the beams. Should I use center to center or edge to edge?
I tried it in both ways. Both gave same volume but different lengths in properties palette.
jeevan
*Expert Elite*
ccollins
Message 2 of 3 (112 Views)
Re: length of the beam ?
12-11-2012 08:23 AM in reply to: jeevanjacob
There is a beam "cut back length" that allows for connection plates, etc.
Take a look in the beam family properties.
Typically, beams are placed from center to center of columns, and the cut-back length automatically pulls the ends away
the specified dimension.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
jeevanjacob
Message 3 of 3 (88 Views)
12-11-2012 08:28 PM in reply to: ccollins
Hi Collins,
Thank you.
May I rephrase my question? I need to export the structural frame, for analysis, to STAAD. For the purpose, center to center is the right method. But as I inserted all my beams, using grid option in the toolbar, I got edge to edge only. Is there a method to overcome this (other than rearranging each and every beam)?
regards
jeevan
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
