Revit Architecture
*Geoffrey Makstutis
Message 1 of 6 (62 Views)
just a leader
62 Views, 5 Replies
05-28-2004 02:45 AM
This is probably something really simple, but... Is there a way to create just a leader line with arrowhead and no note attached? I've got a not with a leader and I want the note to refer to two different points, so I'd like to just add another leader. Any suggestions? Thanks
*Christopher Zoog
Message 2 of 6 (62 Views)
Re: just a leader
05-28-2004 03:16 AM in reply to: *Geoffrey Makstutis
Select the text you want to add a leader to, in the options bar across the top you should see "add a leader" buttons. You can add as many leaders as you like. -Z Geoffrey Makstutis wrote: > This is probably something really simple, but... Is there a way to > create just a leader line with arrowhead and no note attached? > > I've got a not with a leader and I want the note to refer to two > different points, so I'd like to just add another leader. > > Any suggestions? > > Thanks
*Christopher Zoog
Message 3 of 6 (62 Views)
Re: just a leader
05-28-2004 03:18 AM in reply to: *Geoffrey Makstutis
*Geoffrey Makstutis
Message 4 of 6 (62 Views)
Re: just a leader
05-28-2004 08:02 AM in reply to: *Geoffrey Makstutis
I knew it was going to be something so obvious I would kick myself. Thanks Christopher Zoog wrote: > Select the text you want to add a leader to, in the options bar across > the top you should see "add a leader" buttons. You can add as many > leaders as you like. > > -Z > > > Geoffrey Makstutis wrote: > >> This is probably something really simple, but... Is there a way to >> create just a leader line with arrowhead and no note attached? >> >> I've got a not with a leader and I want the note to refer to two >> different points, so I'd like to just add another leader. >> >> Any suggestions? >> >> Thanks
Message 5 of 6 (62 Views)
Re: just a leader
07-26-2004 11:49 PM in reply to: *Geoffrey Makstutis
related to that, do you happen to know how one can control the start point (text end) of the leader? I have put an extra label (which I want) under my keynote box and it has forced the leader to come down off the box centre line. Works fine, it's just ugly. Any ideas?
Distinguished Contributor
Message 6 of 6 (62 Views)
Re: just a leader
07-27-2004 08:29 AM in reply to: *Geoffrey Makstutis
Reposition the text and the leader start point will change, resize the text window and the text will wrap too which can affect the position of the leader. Experiment with the grips that are exposed when you select the text and you'll start to see what your options are.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
