just a leader
5 REPLIES 5
141 Views, 5 Replies
just a leader
This is probably something really simple, but... Is there a way to create just a leader line with arrowhead and no note attached? I've got a not with a leader and I want the note to refer to two different points, so I'd like to just add another leader. Any suggestions? Thanks
5 REPLIES 5
Select the text you want to add a leader to, in the options bar across the top you should see "add a leader" buttons. You can add as many leaders as you like. -Z Geoffrey Makstutis wrote: > This is probably something really simple, but... Is there a way to > create just a leader line with arrowhead and no note attached? > > I've got a not with a leader and I want the note to refer to two > different points, so I'd like to just add another leader. > > Any suggestions? > > Thanks
I knew it was going to be something so obvious I would kick myself. Thanks Christopher Zoog wrote: > Select the text you want to add a leader to, in the options bar across > the top you should see "add a leader" buttons. You can add as many > leaders as you like. > > -Z > > > Geoffrey Makstutis wrote: > >> This is probably something really simple, but... Is there a way to >> create just a leader line with arrowhead and no note attached? >> >> I've got a not with a leader and I want the note to refer to two >> different points, so I'd like to just add another leader. >> >> Any suggestions? >> >> Thanks
sam ak
related to that, do you happen to know how one can control the start point (text end) of the leader? I have put an extra label (which I want) under my keynote box and it has forced the leader to come down off the box centre line. Works fine, it's just ugly. Any ideas?
Steve_Stafford
Reposition the text and the leader start point will change, resize the text window and the text will wrap too which can affect the position of the leader. Experiment with the grips that are exposed when you select the text and you'll start to see what your options are.
Rail Community
