Once 'imported', the DWG will be like a block in Revit. You will have to
explode the imported DWG in Revit to select an individual item. Although
exploding large imported DWGs is not recommended. Do as Aaron said, and go
to View>Visibility>Imported and there you will have layer control to turn
layers on or off.
"nsgarrod" wrote in message
news:20515344.1100090784130.JavaMail.jive@jiveforum1.autodesk.com...
> I am trying to import my project from Architectural Desktop onto Revit. My
problem is that Revit does not recognize each layer. When I try to select
just one thing, it selects the whole project. Is there a way that I can fix
this, or should I import it into VIZ?
> Thanks
