Revit Architecture
Distinguished Contributor
Message 1 of 7 (150 Views)
importing CAD
150 Views, 6 Replies
05-21-2012 04:26 PM
I got a 3d model in dwg format.
I imported it into Revit Architecture.
I came in as 1 entity.  I tried to partial explode/full explode it and it became some single lines only.
What's the reason of it?
Valued Mentor
vector2
Message 2 of 7 (146 Views)
Re: importing CAD
05-21-2012 05:08 PM in reply to: diesellam
That's because a dwg 3d wireframe IS one entity.
What exactly do you want to do with it?
Message 3 of 7 (144 Views)
Re: importing CAD
05-21-2012 05:12 PM in reply to: vector2
I kind of want to explode it and so that they are not in 1 entity, have the ability to move the pieces around if needed to be since the 3d model was created in other 3d modeling software.
Valued Mentor
vector2
Message 4 of 7 (139 Views)
Re: importing CAD
05-21-2012 05:36 PM in reply to: diesellam
diesellam wrote:
"I kind of want to explode it.. move the pieces around"
Please explain why you would want these things.
Message 5 of 7 (131 Views)
Re: importing CAD
05-21-2012 05:47 PM in reply to: vector2
The guy who created the 3d model doesn't want to make any more changes in his 3rd party software. I have to be the one to make the changes in Revit. So he just saved this file as a DWG so that I can import it. I thought after you import it, I can explode it and make the changes. It doesn't work that way?
Valued Mentor
vector2
Message 6 of 7 (122 Views)
Re: importing CAD
05-21-2012 06:34 PM in reply to: diesellam
His "3rd party" software cannot make changes to your
Revit model any more than you can use Revit to make
changes to his model. If you both wanted to make changes
to each others' model, you would both need to be using
the same program.
Active Contributor
sagar.londonites
Message 7 of 7 (104 Views)
Re: importing CAD
05-21-2012 11:18 PM in reply to: diesellam
Revit won't allow you to explode the file and make changes to it. Sketchup does it, not Revit. Instead you can try one of the followings -
1. Use Sketchup if you want to explode the CAD file and make changes to it.
2. Link the CAD in Revit and use it as a reference to model it completely in Revit, then forget the CAD and make changes to Revit.
3. Do the changes directly in CAD file.
- Sagar
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
