ignore unresolved references
6 REPLIES 6
cutama
877 Views, 6 Replies
Is there an option in Revit to automatically ignore unresolved references and continue opening the file without showing the dialog box?
6 REPLIES 6
vector2
in reply to: cutama
I highly doubt it, and if there is, there's usually a check box
to not show that message again.
cutama
in reply to: cutama
Too bad...but thanks for your answer.
vector2
in reply to: cutama
Here's a half-a-solution that works for me.
When you get an error or some other kind of message
at the bottom right of your screen, move it up near the
top of your screen. That way it will at least pop-up in a
more pleasant location with its buttons close to where
you are working.
parveen.revit
in reply to: cutama
can you supply more information regarding the unresolved references ?
If these are related to link files, you can resolve them after opening the model and this message shouln't pop up next time you open the revit model.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
phengy
in reply to: cutama
There must be a setting because my 2016 AutoCAD opens dwgs with missing Xrefs and no dialog or warning box popups at all. I'm trying to find a way to turn it back on!
RobDraw
in reply to: phengy
Yeah, you're right. Revit is just like AutoCAD.
Rob
Rail Community
