Revit Architecture
jmqrsq
Message 1 of 10 (445 Views)
Accepted Solution
if and conditional formula help
445 Views, 9 Replies
01-15-2013 08:16 AM
is there a way to make a if and conditional statement formula in a family with 3 tests?
For example,
Behind Furniture, Biscuit, Masonry Wall, Hard Ceiling are all yes/no parameters
if(and(Behind Furniture, Biscuit, Hard Ceiling), 0'  0 5/16", if(Behind Furniture, 0'  0 11/64", if(Biscuit, 0'  0 11/64", 0'  0 27/256", if(Masonry Wall, 0'  0 11/64", 0'  0 27/256"))))
what is wrond with my formula?
I am trying to change a dimension  based on what yes/no parameters are checked. It keeps telling me that its "a bad if statement format". It works fine for the first teo dimension tests but when I add this last one I get the error. I need the 3rd dimension to check against 3 yes/no parameters all being = yes before moving on to the next check. I would appreciate the advanced help here.
jmqrsq
Message 2 of 10 (442 Views)
Re: if and conditional formula help
01-15-2013 08:24 AM in reply to: jmqrsq
Ok so I realize what I had wrong there:
if(and(Behind Furniture, Biscuit, Masonry Wall), 0'  0 5/16", if(Behind Furniture, 0'  0 11/64", if(Biscuit, 0'  0 11/64", if(Masonry Wall, 0'  0 11/64", 0'  0 27/256"))))
worked. But now I need the formula to check if any two yes/no parameters = yes then 31/128", if none = yes then 27/256"
Using my parameters mentioned earlier is it possible to achieve what I want to do? If so, then how can I fix this? Myabe there is an easier way?
Again, I appreciate the help!
*Expert Elite*
CADastrophe
Message 3 of 10 (432 Views)
01-15-2013 08:43 AM in reply to: jmqrsq
I'll give you two methods to achieve this:
#1 - OR/AND method (typically better when fewer parameters are involved):
if(and(Behind Furniture, Biscuit, Masonry Wall), 0'  0 5/16", if(or(and(Behind Furniture, Biscuit), and(Behind Furniture, Masonry Wall), and(Biscuit, Masonry Wall)), 0'  0 31/128", if(Behind Furniture, 0'  0 11/64", if(Biscuit, 0'  0 11/64", if(Masonry Wall, 0'  0 11/64", 0'  0 27/256")))))
#2 - IF/SUM method (typically better when many parameters are involved):
if(and(Behind Furniture, Biscuit, Masonry Wall), 0'  0 5/16", if(if(Behind Furniture, 1, 0) + if(Biscuit, 1, 0) + if(Masonry Wall, 1, 0) = 2, 0'  0 31/128", if(Behind Furniture, 0'  0 11/64", if(Biscuit, 0'  0 11/64", if(Masonry Wall, 0'  0 11/64", 0'  0 27/256")))))
Just ask if you have any more questions or if you'd like me to elaborate!
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
jmqrsq
Message 4 of 10 (430 Views)
01-15-2013 08:49 AM in reply to: CADastrophe
Thanks! I figured one way to do it although I was sure there had to be an easier and shorter way to do it:
if(and(Behind Furniture, Biscuit, Masonry Wall), 0'  0 5/16", if(and(Behind Furniture, Biscuit), 0'  0 31/128", if(and(Behind Furniture, Masonry Wall), 0'  0 31/128", if(and(Biscuit, Masonry Wall), 0'  0 31/128", if(Behind Furniture, 0'  0 11/64", if(Biscuit, 0'  0 11/64", if(Masonry Wall, 0'  0 11/64", 0'  0 27/256")))))))
I was wondering if you could combine a if or & and conditional statement or not. I tried to do a search on Google but really wasnt sure what this would be called to use for keywords in my search. =) I will try to decipher what is going on in the examples you suggested to simplify any future formulas I do like this one. Any further explanation would be welcomed by me and any other person who stumbles accross this post.
Cheers!
*Expert Elite*
CADastrophe
Message 5 of 10 (419 Views)
01-15-2013 09:14 AM in reply to: CADastrophe
To elaborate a little:
if(
  or(    < this means that if ANY of the conditional statements below return TRUE, then this returns TRUE
     and(Behind Furniture, Biscuit),               < each of these conditional statements tests
     and(Behind Furniture, Masonry Wall),     every combination of the YES/NO Parameters
     and(Biscuit, Masonry Wall)                         and will return TRUE if two of them are YES.
  , 0'  0 31/128",                             < This is the result return if the OR statement is TRUE
   ,[the remainder of your formula]  < otherwise, it resorts to the remainder of the formula.
if(
  if(Behind Furniture, 1, 0)   < each of these statements test each YES/NO Parameter and returns 1 for YES, 0 for NO.
  if(Biscuit, 1, 0),
  +                         < These results, which will either be 1 or 0, are added together to form the first part of the conditional statement
  if(Masonry Wall, 1, 0),
  = 2
  , 0'  0 31/128",                             < This is the result return if the above statement is true, meaning that the sum of the IF's is 2
Hope this is clear enough!
jmqrsq
Message 6 of 10 (407 Views)
01-15-2013 09:42 AM in reply to: jmqrsq
so is it the SUM boolean convert yes to 1 and no to 0? I always thought Revit auto recognized yes's as 1's and no's as 0's. If I had to guess that is still true here and instead of comparing all the parameters to each other you basically were testing if each one was a yes or no, then adding them up and using that result as a determining factor for the end result. Am I basically right thinking it is that simple?
*Expert Elite*
CADastrophe
Message 7 of 10 (400 Views)
01-15-2013 09:48 AM in reply to: jmqrsq
There is no actual SUM function in Revit. And no, Revit does not interpret 1 and 0 as TRUE and FALSE, hence the need for the first IF statement. Essentially, the multiple 1 or 0 tests create a conditional statement as per the example below.
 = if( 1 + 0 + 1 = 2, 1/32", 1/64")
jmqrsq
Message 8 of 10 (390 Views)
01-15-2013 10:22 AM in reply to: CADastrophe
let me see if I am understanding this right. Tell me if this is a accurate and a working formula:
 if (if (a,1,0) + if (b,1,0) + if (c,1,0) + if (d,1,0) = 2, 1", if (a,1,0) + if (b,1,0) + if (c,1,0) + if (d,1,0) = 3, 2", 3")
a = 1 then the result is 3"
a = 2 then the result is 1"
a = 3 then the result is 2"
a > 3 then the result is 3"
*Expert Elite*
CADastrophe
Message 9 of 10 (382 Views)
01-15-2013 11:11 AM in reply to: jmqrsq
if (if (a,1,0) + if (b,1,0) + if (c,1,0) + if (d,1,0) = 2, 1", if (a,1,0) + if (b,1,0) + if (c,1,0) + if (d,1,0) = 3, 2", 3"))
 This formula will function (albeit with an additional parentheses at the end).
Not quite. Your "a" is a simple Yes/No parameter, not a number, so it can only be YES or NO. Your formula will return the result 1" if exactly two of the parameters (a, b, c ,d) are set to YES. It will return 2" if exactly three of them are set to "YES", and 3" for all other results, (which would be none of them checked, only one of them checked, or all of them checked).
jmqrsq
Message 10 of 10 (371 Views)
01-15-2013 12:36 PM in reply to: CADastrophe
right right. I knew that. Bad choice of using a instead of "result = ...".
I think I have it down now. Again I appreciate your help and explanation.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
