How can i put a picture, in rendering? I made a TV family and i want to put a picture & render can that be done in on revit
Now i have placed a pic in image but it is not vissible in the 3d view or camara view.
Please tell me how to do this if its possible
Thank you
Solved by constantin.stroescu. Go to Solution.
use a Decal:
Constantin Stroescu
i did in the same way but i couldnt see the image at all
its neither avalable in section view nor in 3d view or camera view.
should i attach the project & the image so that you can check what is the problem??
Please find the attached Revit file.
I have placed the decal image in the tv screen but its not geting visible in render or in other views
but when i place a copy in a wall & render its showing the image in the wall but not in the tv screen i want that image in the tv screen.
Please advice what i have to do for that.
Thank you
Be sure you place the Decal on the right face....I've applied another decal ...a Gustav Klimt's cause I didn't find yours....
In my example you can see a rendered image and a Realistic Graphic Display...It will, also , appear in Ray Trace Graphic Display...
Constantin Stroescu
Thank you for the quick reply! I will use Photoshop in 5 minutes rather than beat my head against my desk for hours...
Another way could be using a mapped material by Material Browser ...hope this works in LT....
Constantin Stroescu
What if we add the same image in it as a material property?
I think it will work....!
This actually works and pretty well too. You would have to play around with the image dimensions and the tile part to get it right but otherwise my render using the image as a material came out pretty good.
